Inproper license expired message (no effect on license status) [FIXED]
Started by bertie97, June 05, 2013, 05:19:09 PM
bertie97
FYI
I noticed a flag appear when the background auto update ran, saying the license wasn't eligible & I should upgrade etc.  It's a lifetime license. ???
So I ran the update again (up to .23b) & everything seems fine.  The about dialog says PL is licensed OK.
Hope it stays licensed!
Just thought I would give a heads-up on a possible issue.
bertie97
& again on 6.6.0.12
PL still updates & then says licensed in the about box when I click no...
Thanks for the report. I had another user report this as well. Cursory tests went alright and I unfortunately I didn't get around to investigating more thoroughly before release of v6.6. I'll be looking into what is going on ASAP.
This has been resolved now, on the server-side. If you do see it again, please let me know!
Yup, I see this also today, but I check the code again and it will showing it is fine.
1 year license, expired at December.
Quote from: BenYeeHua on June 16, 2013, 12:38:22 PM
So you did see this message today?
And the license really is expired? Or no?
Quote from: Persona Support on June 21, 2013, 06:30:10 PM
Read the date of post. ;)
And nope, I am still using that license, it will be expired on December.
Can it be network issues causing this?
Like the PL updater fail to connect to Bitsum servers and report it is expired?
Thanks for letting me know! I'm not sure the cause yet. PM or email me the activation code so I can check into this (to be sure I am checking the right one)... I really thought it was addressed, should have done a more through examination :o.
