Main Menu
Process Lasso BHP
Started by Ramesh, January 14, 2024, 02:59:13 PM
Ramesh
When I use Process Lasso Bitsum Highest Performance as my default profile do I need to induce performance mode on individual games .exe
Should I only use BHP as my default profile and turn off induce performance mode.
So it looks something like this
Park Control - Unpark All Cores
BHP default profile
Efficiency Mode OFF rule set manually?
Thank you 👍
You don't need to use them both. I recommend using Performance Mode over the BHP power profile rule. This is because other actions are included in Performance Mode, namely a ProBalance exclusion, and potentially more in the future.
Otherwise, looks good!
