Process Lasso constantly crashing and governor stopping at random intervals
Started by Chiru, August 19, 2024, 04:03:09 AM
Chiru
Hello I recently have been having an issue where project lasso keeps randomly stopping it's own governor and then opening a bunch of itself in my little app icons in the bottom right. After this it proceeds to close all iterations of itself and crash. This causes freezing and a bunch of stutters especially when I'm playing games. I believe this started after version 14.0 or 14.2 but I am unsure. I did try to reinstall lasso and import my preset but the issue continues to persist. Also it doesn't always open a bunch of versions of itself but it does keep crashing and stopping it's own governor. I use the bitsum highest performance and performance mode options when I'm gaming so the freezing + change in power settings really hinders my gameplay. This has been a huge bummer considering process lasso has saved my life when it comes to consistent frames in games and it really sucks that I can't use it properly right now. Does anyone have a similar issue and know a fix or is anyone who works at bitsum aware of this issue ?
Yikes! There aren't any known issues that would account for that. It actually sounds like both the GUI (ProcessLasso.exe) and Governor are being terminated, possibly by an external actor, then relaunched.
Can you copy/paste your INI file from menu item "File / Manually Edit Configuration"?
Then, in the log pane, select all rows with CTRL+A and copy/paste those here.
You can also optionally check to see if any dumps were created. See https://bitsum.com/diag/ for instructions to find them. I don't suspect there are, else you'd have gotten a message box about it.
Finally, if you are getting any other crashes or weird behavior from other apps, run some extended system stress tests to ensure the build integrity of your system.
You can use our contact form to upload this data if you desire more privacy.
Chiru
Quote from: Jeremy Collake on August 20, 2024, 06:47:17 AMYikes! There aren't any known issues that would account for that. It actually sounds like both the GUI (ProcessLasso.exe) and Governor are being terminated, possibly by an external actor, then relaunched.
[Administration]
Version=6100200
ConfigPasswordMD5=
[OutOfControlProcessRestraint]
OocOn=true
ExcludeChildrenOfForeground=true
DisableProBalanceWhenSysIdle=false
ProBalanceDropOneRandomCore=false
DoNotAdjustAffinityIfCustomized=true
OocDisableCoreParkingWhileIn=false
UseEfficiencyMode=false
DisableProBalanceIfSysIdleThisManyMS=30000
TotalProcessorUsageBeforeRestraint=23
PerProcessUsageBeforeRestraint=20
TimeOverQuotaBeforeRestraint=900
PerProcessUsageForRestore=5
PlayOnRestraint=C:\WINDOWS\media\Windows Pop-up Blocked.wav
PlayOnRestore=C:\WINDOWS\media\Windows Feed Discovered.wav
MinimumTimeOfRestraint=4200
MaximumTimeOfRestraint=0
TameOnlyNormal=true
LowerToIdleInsteadOfBelowNormal=false
ExcludeServices=true
PlaySoundOnRestraint=false
PlaySoundOnRestore=false
RestrainByAffinity=false
RestraintAffinity=
ExcludeForegroundProcesses2=true
DoNotLowerPriorityClass=false
LowerIOPriorityDuringRestraint=false
MatchExclusionsByPathnameToo=false
ChangeTrayIconOnRestraint=true
OocExclusions=
OocHardCodedExclusionOverrides=
[GUI]
ClearLogAtExit=false
ShowCPUCoreUtilGraphs=true
ShowGraphLegend=true
ShowGraphCPU=true
ShowGraphResponsiveness=true
ShowGraphMemoryLoad=true
ShowGraphProBalanceEvents=true
ShowGraphSelectedProcessesCPUHistory=true
ProBalanceCountersOnGraph=true
ShowGraphLicenseName=true
ShowPowerProfile=true
GraphShowTooltips=true
ShowCPUUtilityAsPrimary=true
[Advanced]
AutomaticUpdate=false
[Performance]
DefaultsLevel=327942
GracefulWaitTimeInMs=5000
UpdateSpeedGUI=1000
UpdateSpeedCore=1000
[Sampling]
SamplingEnabled=false
SamplingIntervalSeconds=900
SamplingOutputPath=
SamplingIncludePattern=*
SamplingExcludePattern=
[Performance]
ManageOnlyCurrentUser=false
ExitOnCloseWindow=false
SoundsOff=true
IsConfigWritable=true
ForcedMode=false
IgnoreProblematicProcesses=false
IgnoreSuspendedProcesses=false
SetTimerResolutionAtStartup=0
[ForegroundBoosting]
BoostForegroundProcess=false
ForegroundBoostPriorityClass=0x8000
BoostOnlyNormal=true
ForegroundBoostExclusions=
[SystemTrayIcon]
UseStaticIcon=false
ShowResponsivnessInTrayInsteadOfProcessorUsage=false
[Logging]
LogDisable=false
IncludeCommandLines=false
LogSmartTrim=true
LogCPULimiter=true
LogEfficiencyMode=true
LogGroupExtender=true
LogCPUSets=true
LogProBalanceParkingChanges=false
LogProcessExecutions=false
LogProcessTerminations=false
LogProcessesDisallowed=true
LogDefaultPriorityAdjustments=true
LogDefaultAffinityAdjustments=true
LogProBalanceBegin=true
LogProBalanceEnd=true
LogInstanceLimitTerminations=true
LogPowerProfileChanges=true
[MemoryManagement]
SmartTrimIsEnabled=false
SmartTrimWorkingSetTrims=false
SmartTrimClearStandbyList=true
SmartTrimClearFileCache=false
ClearStandbyFreeRAMThresholdMB=2048
ClearStandbyOnlyInPerfMode=true
SmartTrimExclusions=overwatch.exe,rustclient.exe
SmartTrimAutoMinimumRAMLoad=65
MinimumProcessWSSInMb=196
SmartTrimIntervalMins=1
[SysTrayBalloons]
EnableSystemTrayNotification=false
BalloonTipDuration=10000
ShowBalloonsForOocPriorityRestoration=false
[ProcessAllowances]
ApplyInstanceCountLimitsToAllUsers=false
AllowedProcesses=
DisallowedProcesses=
InstanceLimitedProcesses=
InstanceManagedCPUAffinities=
ProcessThrottles=
OneTimeProcessThrottles=
CPULimitRules=
[ProcessDefaults]
NamedAffinities=
DefaultPriorities=discord.exe,above normal,m1-win64-shipping.exe,high,audiodg.exe,high,voicemeeterpro.exe,above normal,scpsl.exe,high,valorant-win64-shipping.exe,high,aimlab_tb.exe,high,insightscapture.exe,above normal,ow-obs.exe,above normal,thefirstdescendant.exe,high,cs2.exe,high,rustclient.exe,high,overwatch.exe,high
DefaultIOPriorities=overwatch.exe,4,voicemeeterpro.exe,3,discord.exe,3,valorant-win64-shipping.exe,3
DefaultMemoryPriorities=overwatch.exe,5
ThreadPriorityBoosts=
DefaultAffinitiesEx=audiodg.exe,0,2,overwatch.exe,0,1-11,valorant-win64-shipping.exe,0,1-11
CPUSets=
KeepRunningProcesses=
[ProcessAllowances]
EfficiencyMode=
[ProcessDefaults]
MatchWildcardsToPathnames=true
MatchOnCommandLine=false
[AdvancedRules]
DivideCPUPercentThresholdsBySystemCPUCount=false
ProcessorGroupExtended=
ProhibitInternetExplorerExceptWhenAny=
WatchdogRules2=
[GamingMode]
GamingModeEnabled=false
GamingChangePowerPlan=true
TargetPowerPlan=Bitsum Highest Performance
GamingModeEngageForSteam=true
AutomaticGamingModeProcessPaths=nierautomata.exe,overwatch.exe,r5apex.exe,resolve.exe,rust.exe,rustclient.exe,valorant-win64-shipping.exe,vrchat.exe,m1-win64-shipping.exe
[PowerManagement]
StartWithPowerPlan=High performance
Display=
PC=
[ProcessDefaults]
DefaultPowerSchemes=scpsl.exe;bitsum highest performance
[PowerSaver]
PowerSaver_IdleTime=300
EnergySaverEnabled=false
EnergySaverForceActivePowerProfile=false
EnergySaverUpPowerProfileName=
EnergySaverEvents=true
DisableEnergySaverDuringGamingMode=false
PowerSaver_TargetGUID=Balanced
PowerSaver_Exclusions=
here you go ! sorry for the late response thank you looking into this i do have a file in the logs folder but did not get any in the temp folders. And also I have been using process lasso for quite some time the crashing just happened recently so I'm sure it's not a hardware issue as I haven't changed my hardware for about 2 years. TT
