Active processes gone..
Started by JamesCPH, October 23, 2024, 06:06:11 AM
JamesCPH
Hello there...
If anyone can help me with this I would be grateful :)
I have undervolted my Cpu with Intel's XTU, and updated the Bios and disabled VMX and UnderVolt Protection.
Now when I open Process Lasso the tab with active processes is empty, what could be the reason?
+ nothing works as before, I can see ....
Those changes should not have affected the Active Processes tab, though it's possible that you don't have any processes that are exceeding the threshold. Pay attention to the slider in the upper-right and put it into the leftmost position. You can also use "Options / Tools / CPU Eater Demo" or "Options / Tools / ThreadRacer" to induce a load and test it.
