newest updates to Battle field 6 and process lasso cause BF6 to crash.
Started by chaos4u, November 25, 2025, 11:44:19 AM
chaos4u
Seems one of the newer updates to Battlefield 6  is having issues with process lasso causing the game to crash.  had to disable ProBalance  to get a stable session.
game was working fine through open beta, and on release.  but the last 2 patches have become problematic.
this on windows 10: 1904
Amd Ryzen 1950x
32 gig system Ram
1 Tb Nvme system drive.
ProBalance should not have been the cause and the issue sounds sporadic, so I'm curious to hear about further observations. But to not rule it out, if you don't mind, a copy of your log after such an event occurs might shed more light on if ProBalance was a factor. You can go through older logs in the LogViewer and copy/paste them here or zip and attach all the log files you find via LogViewer menu item "File > Open Log Folder".
