Main Menu
REG repair set submissions
Started by Jeremy Collake, August 05, 2011, 07:37:43 PM
To create one of these, simply go to the affected key(s) in RegEdit, right-click on it and select 'Export'. It is that simple.
Note that for shell file associations, it is actually very obvious if you look in HKEY_CLASSES_ROOT. The extension is the key name, and you can often see exactly the issue when checking that key's default value. I'll show this in a future screenshot, as the current one has random keys that make it hard to understand. Much of the registry is not so bad for human readability -- other parts are a bit bad though ;)
Contributors will be fully credited, able to maintain a link to a site of your own (from here), and have other privileges and rights. Build your own site with repair sets if you want, now you have a utility you can give people so they can more *safely* use them.
For now, submit then directly to us via email at support@bitsum.com . Be *sure* to include the *exact* Windows Operating System and Service Pack you are using, including any other relevant data about their purpose or relation application(s) and file extensions.
