Main Menu
Park Control Safety
Started by TomasCremin, March 25, 2025, 04:38:54 AM
TomasCremin
Hey guys, I recently heard that using park control to unpark your cpu cores can help increase performance in various games. I am a little hesitant to use it because I am a little concerned of the effect it can have on my cpu. Can using the "bitsum highest performance mode option" in this program harm my cpu, or should it be safe to use?
Don't worry, it is perfectly safe to use and will not harm your CPU.
LloydHolder
Glad that you repied! I've been worrying about this because some people keep saying that they concerned about how the bitsum highest performance mode option in this program harm the cpu
Joamerman
Using Bitsum's "Highest Performance" mode is generally safe, it mainly prevents your CPU from downclocking or parking cores, which can improve responsiveness in some games. However, it may increase power usage and heat over time. If your cooling is solid and you're not running it 24/7, it shouldn't harm your CPU.
alcor
Thanks for explaining Park Control safety! I was also worried about CPU damage, so hearing it's safe from a software engineer is really helpful. Good to know the highest performance mode won't harm my processor.
