Managing thermal spikes in a fanless 65W build using Process Lasso
Started by tifipa2943, April 03, 2026, 05:29:14 AM
tifipa2943
Hey everyone, I've been a long-time lurker on the Bitsum forums, and I'm finally reaching out for some specific advice. I recently completed a completely silent, fanless build using a Streacom DB4 chassis. It's been a dream to finally get rid of the "hum," but it's definitely changed the way I have to think about system stability.
I'm currently running a Ryzen 5 1600, which is a 65W TDP chip. As many of you know, that "65W" rating is often more of a suggestion than a hard rule once the CPU starts boosting. In a passive case where the side panels act as the radiator, heat soak is my biggest enemy. I read a build log recently that pointed out how the clearances for heat pipes on these mini-ITX boards are often less than a millimeter, which really highlights how little margin for error there is when things get hot.
My concern is that even if my  65-watt power module is efficient, a rogue background process—like a surprise Windows update or heavy browser indexing—can push the CPU into a boost state for ten or fifteen minutes. Without any active airflow, that can raise the ambient temperature inside the case to uncomfortable levels.
I'm curious if anyone here has used Process Lasso specifically to "hard cap" their power draw by limiting CPU usage before it hits those thermal-heavy boost clocks? I've played with ProBalance, but I'm wondering if the CPU Limiter is a better tool for strictly staying within a thermal envelope. I'd rather sacrifice a bit of burst speed to ensure the chassis stays at a manageable temperature.
Has anyone here successfully tuned a fanless 65W setup using software to prevent thermal saturation, or is under-volting in the BIOS still the only real solution?
conclusionslob
This usually comes down to rule conflicts or the feature not actually being triggered by a matching condition. I'd double-check that the process name/path in your rule is correct and that no other CPU limiter or ProBalance setting is overriding it. Also worth testing with a very simple rule first to confirm it works, then add complexity step by step.
characterdare
For a fanless build, I'd honestly start with BIOS undervolting/PBO limits first since that directly reduces heat output at the source. Process Lasso can definitely help though — especially CPU Limiter for stopping long background spikes from keeping boost clocks active.
I've seen people combine both: mild undervolt + lower PPT/TDC/EDC limits in BIOS, then use Lasso to keep random background tasks under control. That tends to work better long-term than relying on software alone.
