Anyone Using Process Lasso for Gaming?
Started by johnpark, February 23, 2024, 07:59:19 AM
johnpark
I'm wondering if anyone out there is using Process Lasso to get better hit rego, FPS, etc for gaming?
In particular being able to load certain apps to certain logical cores so core 0 isn't overloaded with tasks, etc?
johnpark
Quote from: johnpark on February 23, 2024, 07:59:19 AMI'm wondering if anyone out there is using Process Lasso to get better hit rego, FPS, etc for gaming?
Any ideas?
That's a common configuration. Simply set CPU affinity rules ('Always') on your game processes if you want to keep them off core 0. You'll have to try it out to know if it's effective in your case though.
EmmaAlva
Gamers interested in maximizing hit registration and FPS should consider a holistic approach to optimization, including hardware upgrades, driver updates, game settings adjustments, and network optimizations, in addition to CPU core assignment using tools like Process Lasso.
sarausa
#4
I think there are still people using Process Lasso to play games because it helps improve performance and stability when playing games.
Coldblackice
#5
I use PL, partly in in the hopes that it does help in gaming, though I haven't been able to definitively/objectively tell whether it's helping in my case or not, at least for the Unity-engine FPS I main (Rust). Given the dynamics of open-world FPS games, combined with the fluidity of other factors like drivers, network hardware/drivers/performance (both local and wide networks), it's difficult to find objective, repeatable metrics to measure benefit conclusively. I'm all ears if anyone knows of any.
Quote from: Jeremy Collake on February 24, 2024, 08:27:33 AMThat's a common configuration. Simply set CPU affinity rules ('Always') on your game processes if you want to keep them off core 0. You'll have to try it out to know if it's effective in your case though.
Quote from: Prile1961 on February 26, 2024, 04:30:23 AMCPU utilization and core allocation can indeed have an impact on factors like hit registration and FPS. By assigning gaming applications to dedicated cores, such as ensuring core 0 isn't overloaded, you may be able to achieve more consistent performance and reduce potential bottlenecks.
Is there a way to measure this definitively beyond just general "feel" of whether it's helping or not? Also, is there any difference/benefit to what core it gets put onto? Or would the benefit mainly be it just not being on the baseline "bottom-floor" core 0?
Quote from: laurawoods on March 17, 2024, 09:28:18 PMYes, I've been using Process Lasso for a while now, mainly to optimize my gaming performance. By assigning specific applications to different logical cores, I've noticed a significant improvement in hit registration and overall FPS stability. Core 0 no longer gets overloaded, leading to smoother gameplay and better responsiveness.
How do you choose which apps to put on what cores? Are the cores uniformly the same, meaning it's merely a matter of finding the least-utilized core to give an app?
Quote from: similarbeans on May 02, 2024, 11:50:51 PMIt's crucial to remember that Process Lasso's gaming efficacy can vary depending on a number of variables, such as the particular game, the hardware, and the system configuration. The resource requirements of different games vary, and some might already be optimized to make good use of the system resources.
If anyone's familiar with Unity FPS games, I'm curious if they have any PL optimizations they set, and/or if forcing "ResizableBAR" alongside PL might help or detract from performance.
Coldblackice
(EDIT)
I found a recent user's experience re: benefits of Process Lasso improving their game performance on a system struggling with DPC latency issues:
https://www.reddit.com/r/nvidia/comments/152xvm9/game_ready_studio_driver_53667_faqdiscussion/jttez8z/
Hopil1963
Bevisflyn
Yes, many gamers use Process Lasso to optimize their gaming experience, including improving hit registration and FPS.
mariahcarey
Quote from: Coldblackice on May 14, 2024, 02:44:12 AM(EDIT)
https://www.reddit.com/r/nvidia/comments/152xvm9/game_ready_studio_driver_53667_faqdiscussion/jttez8z/wordle
It's worth experimenting with different settings to find the optimal configuration for your setup.
asherbonaventure
I'm not sure if Process Lasso improves hit rego or FPS as much as people say. I've tried it a few times, but the results are inconsistent. Sometimes FPS is more stable, but other times it's the same as without it. I think most hit rego issues are network and game server-related, not CPU-related.
Hypnotic
Yes i'm using it for gaming but its much more then that also it's not magic bullets ( it will not make something revolutionary ) as far as i know, it will give you the most control over your hardware than any software .
I'm still learning and may be will never fully learn the all potential of the pl but you are definitely will make your games more stable ( in the input lag and fps section ) and maybe you'll see a noticeable fps boost ( the second is very individual ) + you will save some money on your electricity bills and will have cooled and silend hardware with extended lifespan - in my book i cannot imagine a computer without process lasso  ;)
postscript :
of course what i'm explained above happens only when you setting it up correctly and by your needs .
shuwam
https://www.reddit.com/r/nvidia/comments/152xvm9/game_ready_studio_driver_53667_faqdiscussion/jttez8z/slope game
It's great to hear how Process Lasso has positively impacted your game performance! Tackling DPC latency issues can be a game changer, and it's impressive to see tools like this making a real difference.
nuggets
7800X3D
For gaming I use Process Lasso for other way round - i.e. to minimise impact to games from non-windows apps.
MSI Afterburner
Dropbox
OneDrive
Razer/Steelseries software
Mullvad VPN
Discord
and their associated services
I set them all to use only last cpu core, so it minimises impact to games. But for game processes themselves I leave them default.
I purchased Process Lasso and recommended to friends.  :)
MargarLaboyed
https://www.reddit.com/r/nvidia/comments/152xvm9/game_ready_studio_driver_53667_faqdiscussion/jttez8z/wordle unlimited
Interesting! Process Lasso tackling DPC latency is a game-changer (pun intended!). I've heard similar stories. For those still struggling, optimizing CPU affinity and priority can help.
demetee
https://www.reddit.com/r/nvidia/comments/152xvm9/game_ready_studio_driver_53667_faqdiscussion/jttez8z/attractive face test
That's interesting to hear. Process Lasso can definitely help in situations like that by managing CPU priorities and preventing background processes from causing spikes. For systems struggling with DPC latency, even small improvements in scheduling and core usage can translate into noticeably smoother gameplay, so it makes sense that the user saw better performance.
Ronald297
#16
Quote from: Hopil1963 on July 19, 2024, 12:24:51 AMHow to Use Process Lasso to Improve Gaming Performance ANY GAME!: https://www.youtube.com/watch?v=M2TEEq5tIGM
This guide is really helpful for gamers who want to optimize their PC performance and get smoother gameplay in any game.
fluidgorillas
Quote from: Bevisflyn on July 23, 2024, 03:56:11 AMYes, many gamers use Process Lasso to optimize their gaming experience, including improving hit registration and FPS.
that's right
Shinra
Quote from: Hopil1963 on July 19, 2024, 12:24:51 AMHow to Use Process Lasso to Improve Gaming Performance ANY GAME!: https://www.youtube.com/watch?v=M2TEEq5tIGMmoviebox
Thanks for the guide pal. It helped.
