GPU utilization showing 0% since update...
Started by Alyred, May 01, 2026, 12:59:11 PM
Alyred
Hi!  Registered for the forums because I can't figure this out.  Didn't see another post on it in the Process Lasso section.
Since updating recently, the GPU use in Process Lasso has been showing 0% - I'm not sure if this was the process lasso update on the 4th of April, or if it was the newer nVidia driver that was released about a week ago because I haven't done anything that would have pushed the GPU that caused me to notice.
Is this a configuration option (seeing the wrong GPU, even though it's disabled in my 9950x3d?  Or is there an issue between Process Lasso and the newer nVidia driver and I just need to wait for an update (if so, that's okay!)
My GPU is showing normal usage in Windows' performance monitor.
GPU drivers are Nvidia 596.36 Gaming Ready drivers, hardware is a 5090 ASUS Astral, on an X870E MSI Carbon Wifi motherboard.
Thanks!
MB: MSI MPG X870E Carbon WiFi
CPU: AMD Ryzen™ 9 9950x3d
RAM: Corsair DDR5 64GB (CMP64GX5M2B6400C32)
GPU: ASUS 5090 Astral OC
Would you be open to trying the v18.1 beta, which has multiple GPU support? This will test the "picked the wrong GPU" theory.
Download: https://dl.bitsum.com/files/beta/processlassosetup64.exe
If you are able, let me know how it goes!
Alyred
I installed the beta from your link, and it does appear to track my GPU use now.  I'll give it a few shutdowns and suspends to make sure it's able to resume properly and let you know!
Thanks!
Thanks for confirming! We'll have a new release version out soon.
Alyred
Sounds good! Numerous system suspends and restarts and the GPU stats are still displaying normally. Is there anything that I'll need to do to "update" from the Beta back to the release branch, or should it catch the release as a normal update?
Keep menu item "Updates > Include Betas" unchecked and when we issue the release version, probably tomorrow, the beta updates will stop then (you'll be back on the release channel).
Alyred
The release version was issued, but so was a newer beta, so to get off the beta channel you may need to run the release installer again (over-top): https://dl.bitsum.com/files/processlassosetup64.exe
