Excluded processes with paths ignored?
Started by Martin, July 07, 2014, 05:46:47 PM
Martin
Hi!
  I'm using v6.8.0.6 and just found what looks like a bug:
I usually set antivirus and firewall as excluded not to stall the entire machine waiting for those files/packets.
(Formatted for clarity)
OocExclusions=
c:\program files\comodo\comodo internet security\*.exe,
c:\program files\eset\eset endpoint antivirus\egui.exe,
c:\program files\eset\eset endpoint antivirus\x86\ekrn.exe,
d:\program files (x86)\malwarebytes anti-malware\mbam.exe,
d:\program files (x86)\malwarebytes anti-malware\mbamservice.exe,
distnoted.exe,
egui.exe,
ekrn.exe,
processlasso.exe,
procexp.exe,
procexp64.exe
My problem is that none of the entries with paths work (X in rules), with the box "Check process path" checked or not. As soon as I remove the no-path entries, the exclusion drops (X not present). The entries with paths are still present and should take over...?
offchu
Try with 'Options > General Settings > Ignore problematic processes' unhecked.
I am tracking this issue. I will update soon. Thank you for reporting it!
