Licensed User Update Dialog - Activation code will be automatically populated
Started by Jeremy Collake, September 04, 2011, 08:26:47 PM
- Activation code will be automatically populated in license validation box
First, to be clear, the license validation shown upon update notification is optional. If you know when your license will expire (if ever), don't worry about it. The fact that it is optional was not clearly shown though, so many took it as mandatory, or were truly concerned that their license is about to expire. Either way, they went to the tedious trouble of finding and entering their key every update. I apologize for that!
This dialog is now auto-populated with the license activation code. Checking your license to ensure you are still able to get updates will be a one-click, or perhaps zero-click, option from now on.
This change will be in v5.0.0.46. However, you will not see it until the first update after that. Until then, remember, it is optional.
Of course, for lifetime users, ignore all this.
