Main Menu
Timer Resolution
Started by Hypnotic, June 02, 2023, 05:09:56 AM
Hypnotic
Hello wonderful people i'm hoping somebody more addvanced / more aware of the software can help me ;D
Can i use this https://timerresolution.com/ - Timer Resolution software without interference the working of process lasso in games ?
Yes, you can use that tool along-side Process Lasso without any complications.
However, Process Lasso now has its own system timer resolution tool, and that includes persistence capabilities so you don't have to reset it every time you reboot. Find it at menu item 'Tools / System Timer Resolution'. So, use of an additional tool is not necessary, but if you want to use both simultaneously for some reason, it will be fine.
Hypnotic
I didn't know we had that option already from May 23 2023 you guys are crazy good ( i just wanted to try this and we have it build in already ) :D this is even better thank you ...
