Startup for non-admin users
Started by PatrickM, September 13, 2025, 10:49:00 PM
PatrickM
Hello.  I have Process Lasso installed on a windows 11 pro machine.
My issue is that I share this computer with other family members. These other users are set up as "Normal" users without administrative privileges.
When they login, they are presented with a UAC prompt to allow Process Lasso to run. But they do not have the privileges to run this.
The issue is: They cannot cancel the app.   Saying no to the UAC prompt just restarts Process Lasso and the UAC  comes back.
Is there a way that I can run Process lasso for ONLY me (the system admin)?
Thank you for your time.
Yes, open menu item "Options > General > Configure Startup...".
Then in the first section (GUI startup) select "Start at login only for ...".
Click the "Next" then "Finish" buttons to complete the change.
