A few clarifications
Started by Peppo, April 08, 2026, 04:10:49 PM
Peppo
Sincere greetings and heartfelt thanks :)
A few clarifications:
- Is it possible to change the custom color, including for "GPU Graphics"?
- We could be wrong, but it seems that lately, ProBalance works in "standard" mode, but ProBalance doesn't work in "performance" mode.
Thank you for your attention :)
I had hoped nobody was actually using those custom colors so that we could kill those off, but since you asked: Yes, we'll add a custom color selection for the GPU use ;).
ProBalance should not behave differently with respect to Performance Mode, so my guess is there is another factor. If you continue to see any unexpected behavior, do let me know and we'll try to discern the cause.
Peppo
It is confirmed (again, hoping there is no misunderstanding) XD
ProBalance does not work in Performance mode.
Test performed on ProcessLasso with a complete reset to default settings.
Leaving "default" mode and launching a decompression program, ProBalance limit the executable.
Closing everything and repeating after enabling "Performance" mode, ProBalance does not limit the executable.
This also occurs when test with "Balanced" power profile, ProBalance limit
also test with "Performance" power profile, ProBalance does not work.
On all tests all cores always work at 100% full with every profile.
Do you observe the failure to act on the CPUEater tool as well? We are theorizing on this but have not yet reproduced it. Of course, when you use the per-process "Induce Performance Mode" setting that process is excluded from ProBalance, but that does not sound like the case here.
v18.0.1.9 BETA adds the requested GPU custom color setting ;).
Peppo
#4
Tested with CpuEater
Removed from ProBalance "ignore foreground processes, do not affect children, don't act on a different priority,
exclude system services".
In "Standard" mode with the "Balanced" power profile ProBalance works (testlasso.exe priority normal change to minor-)
In "Performance Mode Enabled" mode ProBalance does not work (testlasso.exe priority does not change and remains normal)
In "Performance Mode Disabled" mode with "High Performance" power profile ProBalance does not work (testlasso.exe priority does not change and remains normal)
Options changed before starting CpuEater, all tested individually several times,
For the color and improvements, always excellent. :)
Thanks! So now we know the power profile change is the primary factor.
We'll continue to chew on this and get back to you.
For the sake of completeness, can you confirm if any log entries are emitted during your failing tests?
We have still not come up with any plausible theory as to how the change in power profile would impact ProBalance. The CPU thresholds are CPU Time %, not CPU Utility %, so aren't impacted by frequency scaling, and even if they were CPU Utility %, the 100% load you're testing with would blow past the thresholds under any scenario. We may have to send a debug build to get some tracing to see what the logic is doing.
I've went ahead and created the debug build. This will emit debug data for processes matching testlasso.exe or that begin with 7z (I assumed that was what you were testing with).
Use DebugView to view the output. You'll need to run it as an administrator and enable menu item "Capture > Capture Global Win32".
If you try it, please paste or upload the debug log here. Thank you!
Peppo
#8
Installed Debug build
"ignore foreground processes, do not affect children, don't act on a different priority, exclude system services".
Tested with CpuEater (20 seconds).
Test 1
In "Standard" mode with the "Balanced" power profile:
Log entries are emitted
Test 2
In "high performance" power profile:
Not any log entries are emitted
Test 3
In "Performance Mode" mode with "Bitsum Highest Performance" power profile:
With all Tests after CpuEater started Degugview
(dbgview64.exe run it as an administrator, enable menu "Capture > Capture Global Win32")
Peppo
Test 1
00000001    0.00000000    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=35.32 totalThresh=70 procThresh=10
00000002    0.00002030    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000003    0.00005180    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=0
00000004    0.00009170    17892    pg.ooc: lowering process priority
00000005    0.00010350    17892    PBTrace [testlasso.exe:11492]: timing check. nCurrent=10000000 nTimeOverQuota=27000000 (ms: 1000 vs 2700)
00000006    0.00012100    17892    pg.ooc: Not yet time to restrain...
00000007    0.12779540    4592    SendData len:2 Total time:219
00000008    0.23976320    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:22 #220.0 005 24.00 50.0
00000009    0.52128130    4592    SendData len:3 Total time:204
00000010    0.78537917    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 023 49.5 27.0 20.8 00001001
00000011    0.86091119    4592    Value:1------ID:567
00000012    0.86097717    4592    Value:0------ID:566
00000013    0.86103451    4592    Value:0------ID:565
00000014    0.86108857    4592    Value:1------ID:564
00000015    0.86114019    4592    Value:0------ID:563
00000016    0.86119097    4592    Value:0------ID:562
00000017    0.86124092    4592    Value:0------ID:561
00000018    0.86129022    4592    Value:0------ID:560
00000019    0.86133242    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000020    1.01435959    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=38.97 totalThresh=70 procThresh=10
00000021    1.01439226    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000022    1.01441550    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=1 inRestraint=0
00000023    1.01442981    17892    pg.ooc: lowering process priority
00000024    1.01444352    17892    PBTrace [testlasso.exe:11492]: timing check. nCurrent=20160504 nTimeOverQuota=27000000 (ms: 2016 vs 2700)
00000025    1.01446617    17892    pg.ooc: Not yet time to restrain...
00000026    2.02982569    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=58.85 totalThresh=70 procThresh=10
00000027    2.02984285    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000028    2.02985930    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=1 inRestraint=0
00000029    2.02987766    17892    pg.ooc: lowering process priority
00000030    2.02989650    17892    PBTrace [testlasso.exe:11492]: timing check. nCurrent=30299647 nTimeOverQuota=27000000 (ms: 3029 vs 2700)
00000031    2.02991319    17892    pg.ooc: time to restrain
00000032    2.02993202    17892    pg.ooc: no affinity change indicated
00000033    2.02995157    17892    PBTrace [testlasso.exe:11492]: final gate. bSkipDueOtherFactors=0 bDisallowIdle=0 origPriority=32 tameOnlyNormal=0
00000034    2.05856371    4592    SendData len:3 Total time:78
00000035    2.29689884    17628    InterProcess: begin restraint timing, PID 11492 action 0x2b
00000036    2.29693484    17628    Begun event on 11492 at- 134206173143874848. Total accumulated count is now 1
00000037    2.29696131    17628    Adding ProBalance event for pid 11492:testlasso.exe at 134206173140000000
00000038    2.44682837    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 027 50.4 27.0 20.8 00001001
00000039    2.46351671    4592    Value:1------ID:567
00000040    2.46352458    4592    Value:0------ID:566
00000041    2.46360350    4592    Value:0------ID:565
00000042    2.46366000    4592    Value:1------ID:564
00000043    2.46371198    4592    Value:0------ID:563
00000044    2.46376443    4592    Value:0------ID:562
00000045    2.46381354    4592    Value:0------ID:561
00000046    2.46386290    4592    Value:0------ID:560
00000047    2.46390438    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000048    2.94816852    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000049    2.94824481    17628    Legacy ProBalance event triggered
00000050    3.03745246    17892    pg.ooc: lowering process priority
00000051    3.03754735    17892    pg.ooc: Not yet time to restrain...
00000052    3.03775430    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=87.18 totalThresh=70 procThresh=10
00000053    3.03786230    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000054    3.03787446    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000055    3.03793621    17892    pg.ooc: unrestrain
00000056    3.03797793    17892    pg.Process in restraint, current is 1015 MS restrained vs Minimum Time for Restraint 2100 MS
00000057    3.49185157    4592    SendData len:3 Total time:15
00000058    3.94316912    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 224.0 027 49.5 27.0 20.8 00001001
00000059    3.94323564    4592    Value:1------ID:567
00000060    3.94333410    4592    Value:0------ID:566
00000061    3.94336367    4592    Value:0------ID:565
00000062    3.94343328    4592    Value:1------ID:564
00000063    3.94349551    4592    Value:0------ID:563
00000064    3.94354153    4592    Value:0------ID:562
00000065    3.94359159    4592    Value:0------ID:561
00000066    3.94364882    4592    Value:0------ID:560
00000067    3.94368482    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000068    3.94458723    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000069    4.04171419    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=76.41 totalThresh=70 procThresh=10
00000070    4.04173470    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000071    4.04175854    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000072    4.04178524    17892    pg.ooc: unrestrain
00000073    4.04180813    17892    pg.Process in restraint, current is 2015 MS restrained vs Minimum Time for Restraint 2100 MS
00000074    4.94219303    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000075    4.96485138    4592    SendData len:3 Total time:16
00000076    5.04818487    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=65.20 totalThresh=70 procThresh=10
00000077    5.04820728    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000078    5.04822874    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000079    5.04824162    17892    pg.ooc: unrestrain
00000080    5.04826593    17892    pg.Process in restraint, current is 3015 MS restrained vs Minimum Time for Restraint 2100 MS
00000081    5.42077303    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 027 50.2 27.0 20.8 00001001
00000082    5.43641233    4592    Value:1------ID:567
00000083    5.43648100    4592    Value:0------ID:566
00000084    5.43654251    4592    Value:0------ID:565
00000085    5.43657541    4592    Value:1------ID:564
00000086    5.43661928    4592    Value:0------ID:563
00000087    5.43666983    4592    Value:0------ID:562
00000088    5.43671894    4592    Value:0------ID:561
00000089    5.43676805    4592    Value:0------ID:560
00000090    5.43681002    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000091    5.95054579    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000092    6.05594969    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=64.63 totalThresh=70 procThresh=10
00000093    6.05597115    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000094    6.05598927    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000095    6.05601263    17892    pg.ooc: unrestrain
00000096    6.05603504    17892    pg.Process in restraint, current is 4031 MS restrained vs Minimum Time for Restraint 2100 MS
00000097    6.46521187    4592    SendData len:3 Total time:16
00000098    6.91906977    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 224.0 027 50.3 27.0 20.8 00001001
00000099    6.93540955    4592    Value:1------ID:567
00000100    6.93557024    4592    Value:0------ID:566
00000101    6.93576479    4592    Value:0------ID:565
00000102    6.93587589    4592    Value:1------ID:564
00000103    6.93603277    4592    Value:0------ID:563
00000104    6.93623590    4592    Value:0------ID:562
00000105    6.93637943    4592    Value:0------ID:561
00000106    6.93646145    4592    Value:0------ID:560
00000107    6.93652487    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000108    6.94797897    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000109    7.06958866    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=62.50 totalThresh=70 procThresh=10
00000110    7.06961298    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000111    7.06962967    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000112    7.06964970    17892    pg.ooc: unrestrain
00000113    7.06966877    17892    pg.Process in restraint, current is 5046 MS restrained vs Minimum Time for Restraint 2100 MS
00000114    7.94514418    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000115    7.96894741    4592    SendData len:3 Total time:16
00000116    8.06910229    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=91.03 totalThresh=70 procThresh=10
00000117    8.06912613    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000118    8.06914520    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000119    8.06916428    17892    pg.ooc: unrestrain
00000120    8.06918335    17892    pg.Process in restraint, current is 6046 MS restrained vs Minimum Time for Restraint 2100 MS
00000121    8.42315197    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 027 50.2 27.0 20.8 00001001
00000122    8.43920517    4592    Value:1------ID:567
00000123    8.43930817    4592    Value:0------ID:566
00000124    8.43938732    4592    Value:0------ID:565
00000125    8.43946266    4592    Value:1------ID:564
00000126    8.43949986    4592    Value:0------ID:563
00000127    8.43956280    4592    Value:0------ID:562
00000128    8.43961430    4592    Value:0------ID:561
00000129    8.43966579    4592    Value:0------ID:560
00000130    8.43970966    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000131    8.94174767    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000132    9.07325459    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.09 totalThresh=70 procThresh=10
00000133    9.07328033    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000134    9.07337475    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000135    9.07345486    17892    pg.ooc: unrestrain
00000136    9.07356167    17892    pg.Process in restraint, current is 7046 MS restrained vs Minimum Time for Restraint 2100 MS
00000137    9.46861935    4592    SendData len:3 Total time:16
00000138    9.92123222    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 226.0 027 49.6 27.2 20.8 00001001
00000139    9.93765545    4592    Value:1------ID:567
00000140    9.93788433    4592    Value:0------ID:566
00000141    9.93808270    4592    Value:0------ID:565
00000142    9.93820477    4592    Value:1------ID:564
00000143    9.93852139    4592    Value:0------ID:563
00000144    9.93883228    4592    Value:0------ID:562
00000145    9.93900681    4592    Value:0------ID:561
00000146    9.93911552    4592    Value:0------ID:560
00000147    9.93921280    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000148    9.95065880    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000149    10.07485962    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.66 totalThresh=70 procThresh=10
00000150    10.07487965    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000151    10.07489872    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000152    10.07491684    17892    pg.ooc: unrestrain
00000153    10.07493591    17892    pg.Process in restraint, current is 8046 MS restrained vs Minimum Time for Restraint 2100 MS
00000154    10.94670010    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000155    10.96532154    4592    SendData len:3 Total time:16
00000156    11.08322239    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.61 totalThresh=70 procThresh=10
00000157    11.08324623    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000158    11.08326626    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000159    11.08329391    17892    pg.ooc: unrestrain
00000160    11.08330727    17892    pg.Process in restraint, current is 9046 MS restrained vs Minimum Time for Restraint 2100 MS
00000161    11.41074371    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 226.0 027 49.6 27.2 20.8 00001001
00000162    11.42853642    4592    Value:1------ID:567
00000163    11.42864132    4592    Value:0------ID:566
00000164    11.42870998    4592    Value:0------ID:565
00000165    11.42876530    4592    Value:1------ID:564
00000166    11.42880440    4592    Value:0------ID:563
00000167    11.42883396    4592    Value:0------ID:562
00000168    11.42888260    4592    Value:0------ID:561
00000169    11.42893219    4592    Value:0------ID:560
00000170    11.42897320    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000171    11.94481945    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000172    12.09466839    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.47 totalThresh=70 procThresh=10
00000173    12.09469318    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000174    12.09471226    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000175    12.09473324    17892    pg.ooc: unrestrain
00000176    12.09475040    17892    pg.Process in restraint, current is 10062 MS restrained vs Minimum Time for Restraint 2100 MS
00000177    12.45327187    4592    SendData len:3 Total time:15
00000178    12.90749073    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (224.0 000.0 224.0 027 49.5 27.0 20.8 00001001
00000179    12.90756035    4592    Value:1------ID:567
00000180    12.90764523    4592    Value:0------ID:566
00000181    12.90769768    4592    Value:0------ID:565
00000182    12.90775394    4592    Value:1------ID:564
00000183    12.90780830    4592    Value:0------ID:563
00000184    12.90786171    4592    Value:0------ID:562
00000185    12.90791321    4592    Value:0------ID:561
00000186    12.90796566    4592    Value:0------ID:560
00000187    12.90800953    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000188    12.96875000    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000189    13.10663605    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.92 totalThresh=70 procThresh=10
00000190    13.10665798    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000191    13.10669899    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000192    13.10671234    17892    pg.ooc: unrestrain
00000193    13.10673046    17892    pg.Process in restraint, current is 11078 MS restrained vs Minimum Time for Restraint 2100 MS
00000194    13.86983013    6832    Checking directories...
00000195    13.87073326    6832    Directory check complete.
00000196    13.93382835    4592    SendData len:2 Total time:16
00000197    13.96295166    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000198    14.12279797    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.31 totalThresh=70 procThresh=10
00000199    14.12282372    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000200    14.12284279    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000201    14.12286091    17892    pg.ooc: unrestrain
00000202    14.12287998    17892    pg.Process in restraint, current is 12093 MS restrained vs Minimum Time for Restraint 2100 MS
00000203    14.34838867    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:39 #                          V3.65
00000204    14.36412811    4592    SendData len:3 Total time:15
00000205    14.82183361    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 027 50.2 27.2 20.8 00001001
00000206    14.83774376    4592    Value:1------ID:567
00000207    14.83777714    4592    Value:0------ID:566
00000208    14.83783245    4592    Value:0------ID:565
00000209    14.83788490    4592    Value:1------ID:564
00000210    14.83793449    4592    Value:0------ID:563
00000211    14.83798409    4592    Value:0------ID:562
00000212    14.83803368    4592    Value:0------ID:561
00000213    14.83808517    4592    Value:0------ID:560
00000214    14.83812618    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000215    14.96072197    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000216    15.13049126    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.77 totalThresh=70 procThresh=10
00000217    15.13051319    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000218    15.13053322    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000219    15.13055229    17892    pg.ooc: unrestrain
00000220    15.13057137    17892    pg.Process in restraint, current is 13109 MS restrained vs Minimum Time for Restraint 2100 MS
00000221    15.85967541    4592    SendData len:2 Total time:16
00000222    15.95612526    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000223    16.13757515    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=66.18 totalThresh=70 procThresh=10
00000224    16.13759995    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000225    16.13761711    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000226    16.13763618    17892    pg.ooc: unrestrain
00000227    16.13765526    17892    pg.Process in restraint, current is 14109 MS restrained vs Minimum Time for Restraint 2100 MS
00000228    16.19795609    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:22 #220.0 005 24.00 50.0
00000229    16.22953987    4592    SendData len:3 Total time:16
00000230    16.68576622    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 027 49.5 27.2 20.8 00001001
00000231    16.70171547    4592    Value:1------ID:567
00000232    16.70179367    4592    Value:0------ID:566
00000233    16.70181274    4592    Value:0------ID:565
00000234    16.70186996    4592    Value:1------ID:564
00000235    16.70192337    4592    Value:0------ID:563
00000236    16.70200157    4592    Value:0------ID:562
00000237    16.70202637    4592    Value:0------ID:561
00000238    16.70207596    4592    Value:0------ID:560
00000239    16.70211792    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000240    16.95726967    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000241    17.14311028    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=69.73 totalThresh=70 procThresh=10
00000242    17.14312935    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000243    17.14314842    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000244    17.14316750    17892    pg.ooc: unrestrain
00000245    17.14318657    17892    pg.Process in restraint, current is 15109 MS restrained vs Minimum Time for Restraint 2100 MS
00000246    17.74478531    4592    SendData len:3 Total time:31
00000247    17.97161674    17628    pid 11492 is currently in restraint. Total processes in restraint 1
00000248    18.15997696    17892    PBTrace [testlasso.exe:11492]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=65.75 totalThresh=70 procThresh=10
00000249    18.15999603    17892    PBTrace [testlasso.exe:11492]: passed exclusion gate
00000250    18.16001511    17892    PBTrace [testlasso.exe:11492]: thresholds met. timingExcess=0 inRestraint=1
00000251    18.16003609    17892    pg.ooc: unrestrain
00000252    18.16005516    17892    pg.Process in restraint, current is 16125 MS restrained vs Minimum Time for Restraint 2100 MS
00000253    18.18920326    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 225.0 026 50.2 27.2 20.8 00001001
00000254    18.20505142    4592    Value:1------ID:567
00000255    18.20512009    4592    Value:0------ID:566
00000256    18.20517540    4592    Value:0------ID:565
00000257    18.20522881    4592    Value:1------ID:564
00000258    18.20528030    4592    Value:0------ID:563
00000259    18.20532990    4592    Value:0------ID:562
00000260    18.20537949    4592    Value:0------ID:561
00000261    18.20542908    4592    Value:0------ID:560
00000262    18.20547104    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000263    18.96043587    17628    CProBalanceEventHistory::RemoveTrackedPID 11492
00000264    19.22604179    4592    SendData len:3 Total time:16
00000265    19.44976044    17628    InterProcess: end restraint timing, PID 11492 action 0x20
00000266    19.44977570    17628    End restraint timing for 11492
00000267    19.68772888    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (224.0 000.0 225.0 026 49.4 27.2 20.8 00001001
00000268    19.68791962    4592    Value:1------ID:567
00000269    19.68797112    4592    Value:0------ID:566
00000270    19.68802261    4592    Value:0------ID:565
00000271    19.68806839    4592    Value:1------ID:564
00000272    19.68813324    4592    Value:0------ID:563
00000273    19.68816566    4592    Value:0------ID:562
00000274    19.68828011    4592    Value:0------ID:561
00000275    19.68838310    4592    Value:0------ID:560
00000276    19.68840218    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000277    20.70451546    4592    SendData len:3 Total time:15
00000278    21.14885902    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 022 50.2 27.2 20.8 00001001
00000279    21.14894676    4592    Value:1------ID:567
00000280    21.14901733    4592    Value:0------ID:566
00000281    21.14907265    4592    Value:0------ID:565
00000282    21.14912605    4592    Value:1------ID:564
00000283    21.14917755    4592    Value:0------ID:563
00000284    21.14922714    4592    Value:0------ID:562
00000285    21.14927673    4592    Value:0------ID:561
00000286    21.14932442    4592    Value:0------ID:560
00000287    21.14936447    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
00000288    22.16544724    4592    SendData len:3 Total time:15
00000289    22.61052895    4592    D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 022 49.5 27.2 20.8 00001001
00000290    22.62634659    4592    Value:1------ID:567
00000291    22.62640953    4592    Value:0------ID:566
00000292    22.62646484    4592    Value:0------ID:565
00000293    22.62651825    4592    Value:1------ID:564
00000294    22.62657166    4592    Value:0------ID:563
00000295    22.62662125    4592    Value:0------ID:562
00000296    22.62666893    4592    Value:0------ID:561
00000297    22.62671852    4592    Value:0------ID:560
00000298    22.62676048    4592    ¸æ¾¯ 1 0 0 1 0 0 0 0
Peppo
Test 2
00000001   0.00000000   4592   SendData len:2 Total time:281
00000002   0.07128570   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:22 #220.0 005 24.00 50.0
00000003   0.10539340   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=66.00 fUsage=1.60 totalThresh=70 procThresh=10
00000004   0.10540920   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000005   0.10542270   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=66.00 (need>=70) fUsage=1.60 (need>=10)
00000006   0.40706021   4592   SendData len:3 Total time:250
00000007   0.61524272   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (224.0 000.0 225.0 028 49.6 27.2 20.8 00001001
00000008   0.67943400   4592   Value:1------ID:567
00000009   0.67946953   4592   Value:0------ID:566
00000010   0.67950541   4592   Value:0------ID:565
00000011   0.67955887   4592   Value:1------ID:564
00000012   0.67957652   4592   Value:0------ID:563
00000013   0.67962688   4592   Value:0------ID:562
00000014   0.67966270   4592   Value:0------ID:561
00000015   0.67969340   4592   Value:0------ID:560
00000016   0.67971432   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000017   1.11300862   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.81 totalThresh=70 procThresh=10
00000018   1.11301994   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000019   1.11303294   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.81 (need>=10)
00000020   2.26637387   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=3.10 totalThresh=70 procThresh=10
00000021   2.26776791   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000022   2.26881361   4592   SendData len:3 Total time:344
00000023   2.27033520   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=3.10 (need>=10)
00000024   2.42302132   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (224.0 000.0 223.0 050 50.2 27.0 20.8 00001001
00000025   2.55492496   4592   Value:1------ID:567
00000026   2.55494452   4592   Value:0------ID:566
00000027   2.55504513   4592   Value:0------ID:565
00000028   2.55505681   4592   Value:1------ID:564
00000029   2.55509925   4592   Value:0------ID:563
00000030   2.55515480   4592   Value:0------ID:562
00000031   2.55516887   4592   Value:0------ID:561
00000032   2.55520034   4592   Value:0------ID:560
00000033   2.55521870   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000034   3.27288008   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.71 totalThresh=70 procThresh=10
00000035   3.27288890   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000036   3.27290249   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.71 (need>=10)
00000037   3.94577670   4592   SendData len:3 Total time:266
00000038   4.15127897   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (223.0 000.0 224.0 050 50.2 27.0 20.8 00001001
00000039   4.21774054   4592   Value:1------ID:567
00000040   4.21777678   4592   Value:0------ID:566
00000041   4.21779442   4592   Value:0------ID:565
00000042   4.21782541   4592   Value:1------ID:564
00000043   4.21789694   4592   Value:0------ID:563
00000044   4.21795130   4592   Value:0------ID:562
00000045   4.21796417   4592   Value:0------ID:561
00000046   4.21799421   4592   Value:0------ID:560
00000047   4.21801138   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000048   4.28114128   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=3.00 totalThresh=70 procThresh=10
00000049   4.28115463   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000050   4.28116703   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=3.00 (need>=10)
00000051   5.28896570   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.91 totalThresh=70 procThresh=10
00000052   5.28897667   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000053   5.28898859   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.91 (need>=10)
00000054   5.65528393   4592   SendData len:3 Total time:313
00000055   5.79922056   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (223.0 000.0 224.0 051 49.6 27.0 20.8 00001001
00000056   5.81529617   4592   Value:1------ID:567
00000057   5.81533909   4592   Value:0------ID:566
00000058   5.81537199   4592   Value:0------ID:565
00000059   5.81540298   4592   Value:1------ID:564
00000060   5.81543303   4592   Value:0------ID:563
00000061   5.81546783   4592   Value:0------ID:562
00000062   5.81549120   4592   Value:0------ID:561
00000063   5.81551933   4592   Value:0------ID:560
00000064   5.81557417   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000065   6.29646397   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.52 totalThresh=70 procThresh=10
00000066   6.29647779   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000067   6.29649019   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.52 (need>=10)
00000068   7.25503683   4592   SendData len:3 Total time:296
00000069   7.33538818   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.95 totalThresh=70 procThresh=10
00000070   7.33539772   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000071   7.33541536   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.95 (need>=10)
00000072   7.41504812   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (223.0 000.0 224.0 052 49.6 27.0 20.8 00001001
00000073   7.59019136   4592   Value:1------ID:567
00000074   7.59022808   4592   Value:0------ID:566
00000075   7.59026003   4592   Value:0------ID:565
00000076   7.59028959   4592   Value:1------ID:564
00000077   7.59031773   4592   Value:0------ID:563
00000078   7.59034491   4592   Value:0------ID:562
00000079   7.59037209   4592   Value:0------ID:561
00000080   7.59039927   4592   Value:0------ID:560
00000081   7.59042263   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000082   8.34481907   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.82 totalThresh=70 procThresh=10
00000083   8.34483528   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000084   8.34487534   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.82 (need>=10)
00000085   9.03134918   4592   SendData len:3 Total time:282
00000086   9.49491119   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (223.0 000.0 224.0 052 49.4 27.0 20.8 00001001
00000087   9.49493980   4592   Value:1------ID:567
00000088   9.49496651   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.95 totalThresh=70 procThresh=10
00000089   9.49499130   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000090   9.49501705   4592   Value:0------ID:566
00000091   9.49503136   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.95 (need>=10)
00000092   9.49505234   4592   Value:0------ID:565
00000093   9.49508286   4592   Value:1------ID:564
00000094   9.49512196   4592   Value:0------ID:563
00000095   9.49514103   4592   Value:0------ID:562
00000096   9.49516773   4592   Value:0------ID:561
00000097   9.49519444   4592   Value:0------ID:560
00000098   9.49521732   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000099   10.50560760   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.75 totalThresh=70 procThresh=10
00000100   10.50561714   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000101   10.50563240   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.75 (need>=10)
00000102   11.59183693   4592   SendData len:3 Total time:328
00000103   11.59228992   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (223.0 000.0 224.0 053 49.6 27.0 20.8 00001001
00000104   11.60151482   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=3.15 totalThresh=70 procThresh=10
00000105   11.60493565   4592   Value:1------ID:567
00000106   11.60622311   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000107   11.60726357   4592   Value:0------ID:566
00000108   11.60851002   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=3.15 (need>=10)
00000109   11.60971069   4592   Value:0------ID:565
00000110   11.61086273   4592   Value:1------ID:564
00000111   11.61227322   4592   Value:0------ID:563
00000112   11.61549473   4592   Value:0------ID:562
00000113   11.61741257   4592   Value:0------ID:561
00000114   11.61896038   4592   Value:0------ID:560
00000115   11.62009716   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000116   12.63157082   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.92 totalThresh=70 procThresh=10
00000117   12.63164902   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000118   12.63169956   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.92 (need>=10)
00000119   13.00002098   4592   SendData len:3 Total time:265
00000120   13.19152355   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (224.0 000.0 224.0 052 50.4 27.0 20.8 00001001
00000121   13.25522709   4592   Value:1------ID:567
00000122   13.25526619   4592   Value:0------ID:566
00000123   13.25529766   4592   Value:0------ID:565
00000124   13.25533390   4592   Value:1------ID:564
00000125   13.25536537   4592   Value:0------ID:563
00000126   13.25543976   4592   Value:0------ID:562
00000127   13.25546265   4592   Value:0------ID:561
00000128   13.25553131   4592   Value:0------ID:560
00000129   13.25554276   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000130   13.65510273   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.96 totalThresh=70 procThresh=10
00000131   13.65513802   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000132   13.65517235   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.96 (need>=10)
00000133   19.49559212   17892   PBTrace [testlasso.exe:13072]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=3.06 totalThresh=70 procThresh=10
00000134   19.50590134   17628   CProBalanceEventHistory::RemoveTrackedPID 13072
00000135   19.50590324   17892   PBTrace [testlasso.exe:13072]: passed exclusion gate
00000136   19.51903725   4592   SendData len:3 Total time:281
00000137   19.52758980   17892   PBTrace [testlasso.exe:13072]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=3.06 (need>=10)
00000138   19.53034401   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (223.0 000.0 224.0 051 49.5 27.0 20.8 00001001
00000139   19.53192711   4592   Value:1------ID:567
00000140   19.53344345   4592   Value:0------ID:566
00000141   19.53548050   4592   Value:0------ID:565
00000142   19.53724098   4592   Value:1------ID:564
00000143   19.53981400   4592   Value:0------ID:563
00000144   19.54313278   4592   Value:0------ID:562
00000145   19.54497528   4592   Value:0------ID:561
00000146   19.54695320   4592   Value:0------ID:560
00000147   19.54906273   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
Peppo
Test 3
00000001   0.00000000   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=26.00 fUsage=0.00 totalThresh=70 procThresh=10
00000002   0.00002590   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000003   0.00003980   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=26.00 (need>=70) fUsage=0.00 (need>=10)
00000004   0.82509530   4592   SendData len:3 Total time:328
00000005   0.99219489   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (228.0 000.0 228.0 030 50.3 27.2 20.8 00001001
00000006   0.99227488   4592   Value:1------ID:567
00000007   0.99230748   4592   Value:0------ID:566
00000008   0.99233401   4592   Value:0------ID:565
00000009   0.99235821   4592   Value:1------ID:564
00000010   0.99238181   4592   Value:0------ID:563
00000011   0.99240541   4592   Value:0------ID:562
00000012   0.99242890   4592   Value:0------ID:561
00000013   0.99244970   4592   Value:0------ID:560
00000014   0.99257481   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000015   1.00974011   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=3.01 totalThresh=70 procThresh=10
00000016   1.00975084   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000017   1.00976384   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=3.01 (need>=10)
00000018   2.01554656   4592   SendData len:2 Total time:16
00000019   2.01748443   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.77 totalThresh=70 procThresh=10
00000020   2.01749730   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000021   2.01750970   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.77 (need>=10)
00000022   2.43154168   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:39 #                           V3.65
00000023   2.46385288   4592   SendData len:3 Total time:16
00000024   2.91194773   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 226.0 051 49.5 27.2 20.8 00001001
00000025   2.92842269   4592   Value:1------ID:567
00000026   2.92844415   4592   Value:0------ID:566
00000027   2.92847204   4592   Value:0------ID:565
00000028   2.92850089   4592   Value:1------ID:564
00000029   2.92854571   4592   Value:0------ID:563
00000030   2.92858553   4592   Value:0------ID:562
00000031   2.92861342   4592   Value:0------ID:561
00000032   2.92863989   4592   Value:0------ID:560
00000033   2.92864561   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000034   3.02500081   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.91 totalThresh=70 procThresh=10
00000035   3.02501249   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000036   3.02502489   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.91 (need>=10)
00000037   5.09457922   4592   SendData len:2 Total time:15
00000038   5.21107721   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.71 totalThresh=70 procThresh=10
00000039   5.21111298   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:22 #220.0 005 24.00 50.0
00000040   5.21117783   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000041   5.21119881   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.71 (need>=10)
00000042   5.23167658   4592   SendData len:3 Total time:16
00000043   5.67968655   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 226.0 051 49.5 27.2 20.8 00001001
00000044   5.69576979   4592   Value:1------ID:567
00000045   5.69579315   4592   Value:0------ID:566
00000046   5.69581223   4592   Value:0------ID:565
00000047   5.69586229   4592   Value:1------ID:564
00000048   5.69587469   4592   Value:0------ID:563
00000049   5.69589901   4592   Value:0------ID:562
00000050   5.69591665   4592   Value:0------ID:561
00000051   5.69594049   4592   Value:0------ID:560
00000052   5.69595623   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000053   6.22605658   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.96 totalThresh=70 procThresh=10
00000054   6.22606802   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000055   6.22608089   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.96 (need>=10)
00000056   6.71987343   4592   SendData len:3 Total time:16
00000057   7.16811848   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 226.0 052 50.2 27.0 20.8 00001001
00000058   7.18410015   4592   Value:1------ID:567
00000059   7.18412638   4592   Value:0------ID:566
00000060   7.18415737   4592   Value:0------ID:565
00000061   7.18417835   4592   Value:1------ID:564
00000062   7.18419838   4592   Value:0------ID:563
00000063   7.18422651   4592   Value:0------ID:562
00000064   7.18424654   4592   Value:0------ID:561
00000065   7.18426561   4592   Value:0------ID:560
00000066   7.18428326   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000067   7.23405123   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.91 totalThresh=70 procThresh=10
00000068   7.23407936   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000069   7.23408651   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.91 (need>=10)
00000070   8.24017143   4592   SendData len:3 Total time:16
00000071   8.24213123   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.86 totalThresh=70 procThresh=10
00000072   8.24214172   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000073   8.24215508   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.86 (need>=10)
00000074   8.65592194   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (225.0 000.0 225.0 052 50.2 27.0 20.8 00001001
00000075   8.67198086   4592   Value:1------ID:567
00000076   8.67200375   4592   Value:0------ID:566
00000077   8.67202473   4592   Value:0------ID:565
00000078   8.67204380   4592   Value:1------ID:564
00000079   8.67206383   4592   Value:0------ID:563
00000080   8.67208290   4592   Value:0------ID:562
00000081   8.67210197   4592   Value:0------ID:561
00000082   8.67212200   4592   Value:0------ID:560
00000083   8.67213821   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000084   9.27995491   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.81 totalThresh=70 procThresh=10
00000085   9.28002357   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000086   9.28003216   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.81 (need>=10)
00000087   9.69563484   4592   SendData len:3 Total time:15
00000088   10.14430523   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 227.0 052 49.4 27.0 20.8 00001001
00000089   10.15988731   4592   Value:1------ID:567
00000090   10.15993404   4592   Value:0------ID:566
00000091   10.15994930   4592   Value:0------ID:565
00000092   10.16001320   4592   Value:1------ID:564
00000093   10.16002560   4592   Value:0------ID:563
00000094   10.16005516   4592   Value:0------ID:562
00000095   10.16008282   4592   Value:0------ID:561
00000096   10.16010475   4592   Value:0------ID:560
00000097   10.16012955   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000098   10.28989887   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.82 totalThresh=70 procThresh=10
00000099   10.28991127   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000100   10.28992367   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.82 (need>=10)
00000101   11.18412113   4592   SendData len:3 Total time:16
00000102   11.30092335   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.96 totalThresh=70 procThresh=10
00000103   11.30095959   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000104   11.30099392   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.96 (need>=10)
00000105   12.08963776   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 226.0 052 49.5 27.0 20.8 00001001
00000106   12.09531784   4592   Value:1------ID:567
00000107   12.09533310   4592   Value:0------ID:566
00000108   12.09538555   4592   Value:0------ID:565
00000109   12.09540844   4592   Value:1------ID:564
00000110   12.09542847   4592   Value:0------ID:563
00000111   12.09544754   4592   Value:0------ID:562
00000112   12.09546757   4592   Value:0------ID:561
00000113   12.09550285   4592   Value:0------ID:560
00000114   12.09551907   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000115   12.30470181   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=3.01 totalThresh=70 procThresh=10
00000116   12.30471420   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000117   12.30472755   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=3.01 (need>=10)
00000118   13.11969566   4592   SendData len:3 Total time:15
00000119   13.31407452   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.86 totalThresh=70 procThresh=10
00000120   13.31408405   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000121   13.31409645   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.86 (need>=10)
00000122   13.56780624   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (227.0 000.0 228.0 053 50.4 27.2 20.8 00001001
00000123   13.58387184   4592   Value:1------ID:567
00000124   13.58389091   4592   Value:0------ID:566
00000125   13.58391190   4592   Value:0------ID:565
00000126   13.58393288   4592   Value:1------ID:564
00000127   13.58395386   4592   Value:0------ID:563
00000128   13.58397293   4592   Value:0------ID:562
00000129   13.58399391   4592   Value:0------ID:561
00000130   13.58401299   4592   Value:0------ID:560
00000131   13.58403015   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000132   14.33606434   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.81 totalThresh=70 procThresh=10
00000133   14.33612823   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000134   14.33615398   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.81 (need>=10)
00000135   14.60757923   4592   SendData len:3 Total time:16
00000136   15.05615807   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 227.0 052 50.4 27.2 20.8 00001001
00000137   15.08819485   4592   Value:1------ID:567
00000138   15.08825874   4592   Value:0------ID:566
00000139   15.08831024   4592   Value:0------ID:565
00000140   15.08836460   4592   Value:1------ID:564
00000141   15.08839703   4592   Value:0------ID:563
00000142   15.08842754   4592   Value:0------ID:562
00000143   15.08844662   4592   Value:0------ID:561
00000144   15.08849716   4592   Value:0------ID:560
00000145   15.08861256   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000146   15.36000824   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.81 totalThresh=70 procThresh=10
00000147   15.37598038   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000148   15.37615967   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.81 (need>=10)
00000149   15.82470512   6832   Checking directories...
00000150   15.82513237   6832   Directory check complete.
00000151   16.11198425   4592   SendData len:3 Total time:31
00000152   16.38655472   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.77 totalThresh=70 procThresh=10
00000153   16.38656998   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000154   16.38658333   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.77 (need>=10)
00000155   16.56006432   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 226.0 052 49.5 27.0 20.8 00001001
00000156   16.57612038   4592   Value:1------ID:567
00000157   16.57614326   4592   Value:0------ID:566
00000158   16.57616425   4592   Value:0------ID:565
00000159   16.57618332   4592   Value:1------ID:564
00000160   16.57620239   4592   Value:0------ID:563
00000161   16.57622147   4592   Value:0------ID:562
00000162   16.57624245   4592   Value:0------ID:561
00000163   16.57626152   4592   Value:0------ID:560
00000164   16.57627869   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000165   17.39406967   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.91 totalThresh=70 procThresh=10
00000166   17.39407921   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000167   17.39409065   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.91 (need>=10)
00000168   17.63234138   4592   SendData len:3 Total time:47
00000169   18.04824257   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (227.0 000.0 227.0 052 50.4 27.2 20.8 00001001
00000170   18.06432724   4592   Value:1------ID:567
00000171   18.06435394   4592   Value:0------ID:566
00000172   18.06437302   4592   Value:0------ID:565
00000173   18.06439400   4592   Value:1------ID:564
00000174   18.06441307   4592   Value:0------ID:563
00000175   18.06443214   4592   Value:0------ID:562
00000176   18.06445122   4592   Value:0------ID:561
00000177   18.06447029   4592   Value:0------ID:560
00000178   18.06448746   4592   ¸æ¾¯ 1 0 0 1 0 0 0 0
00000179   18.40208054   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.90 totalThresh=70 procThresh=10
00000180   18.40209389   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000181   18.40210724   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.90 (need>=10)
00000182   19.08816719   4592   SendData len:2 Total time:16
00000183   19.41028786   17892   PBTrace [testlasso.exe:13204]: entering ProBalance eval. excluded=0 classifiedAsGame=0 autoGameExclude=0 fTotalUsage=100.00 fUsage=2.86 totalThresh=70 procThresh=10
00000184   19.41043282   17892   PBTrace [testlasso.exe:13204]: passed exclusion gate
00000185   19.41044426   17892   PBTrace [testlasso.exe:13204]: thresholds NOT met. fTotalUsage=100.00 (need>=70) fUsage=2.86 (need>=10)
00000186   19.50404549   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:39 #                           V3.65
00000187   19.53620338   4592   SendData len:3 Total time:16
00000188   19.98313522   4592   D:\cvs_windows\working@PowerManager\RcUsbComm\RCUsbHidComm.cpp 115 onUartDataReady Len:47 (226.0 000.0 226.0 052 49.5 27.0 20.8 00001001
Thanks! This confirms the cause as the per-process CPU Time % utilization being computed differently while you are in High Performance. The difference is quite large, in fact, at <~4% in High Performance vs >~50% in Balanced. For this reason, the test process is never considered over threshold. I'd be curious to hear what Task Manager reports for the TestLasso.exe process in its "Details" view (re: not the other views that instead use CPU Utility %).
Can you please let me know your CPU model? I'm guessing an Intel? Have you customized your power plans in any significant way?
We need to study this issue further before making any adjustments. For that reason, we won't delay today's planned minor release but will begin work on this immediately.
Peppo
Intel CPU should be a 13600k, my brother should have an even higher one.
The "power saving" settings are the standard Windows 11 (except for the monitor off time and hibernation, which have been removed).
If you mean Windows "task manager-details" TestLasso.exe in column CPU (total processor usage for all cores) is always the same "00" in every test.
Peppo
If there is any news on this matter, it would be very welcome :)
Unfortunately, this report is still a mystery to us, but we did spend considerable time researching how it could occur. The best theory we have involves your system integrity, due to the following reasoning:
The per-process CPU use of testlasso.exe suggests something else is consuming most of the CPU cycles at the time of the test in High Performance, preventing testlasso.exe from exceeding the per-process threshold. You can see the total CPU usage at 100%, while testlasso.exe itself barely moves the needle. Your Task Manager observation of testlasso.exe CPU usage confirms it's not just Process Lasso somehow doing math wrong.
Assuming there is another actor, why it is only active in High Performance is unknown. It should also be apparent what that other actor is, yet it seems invisible.
That points to an issue with your system integrity, possibly malware hiding its CPU usage. Now, I have no evidence of that, so don't be alarmed. Still, run an offline scan with Windows Defender at the least.
Peppo
#16
Thanks for the information and advice,
to avoid any doubt, we tried it on a properly reinstalled system without internet access, but the problem persists.
It seemed to us more likely to be due to a "non-recognition" from the energy saving mode, whether manually set or activated by an .exe application rule. The settings are standard Windows and with Balanced energy profile it works but not with the other higher-performance profiles.
Unfortunately we didn't notice it right away, among the various program updates, since ProBalance didn't have to intervene that often. It's a shame for such a useful feature, but it doesn't matter.
Thanks again.
