News:
NOTICE: Registration may require manual admin activation. After registering visit https://bitsum.com/contact/ to request account activation.
Main Menu
Show Graph
Started by ilikefree, June 12, 2015, 10:03:12 PM
ilikefree
Using the latest version of PL Pro show graph/hide graph button does nothing.
Is it just me or has something been changed?
works here fine .
try closing it an reopen, see if that helps .
No changes were made to that area of the code.
It does seem to work fine here as well.
I am not sure what could cause such a failure. That's pretty bizarre.
I would advise an uninstall (export your config first if it is important to you), the reinstall Process Lasso. Maybe that will help ?
Do you use any software like WindowBlinds or anything to change the theme of the Windows UI?
ilikefree
Reinstall fixed it thanks
