Long time paid user, first post - Export CSV in LogViewer with all attributes
Started by Aaron Tiensivu, October 20, 2015, 05:42:35 PM
Aaron Tiensivu
Right now in the current version, only a subset of the fields get exported to a CSV when using LogViewer.
I'd love to see if all possible values from the Log Viewer log file could be exported to CSV, even if it meant encapsulating the cmdline with " " on either end.
I'm really after the cmdlines used and not just the process launched/etc.
I have no idea if this is currently possible (I've looked everywhere I could) so if it is, and I'm not seeing it, how do we do that? :)
yeh, seems commandline data is not in there.
AFAIK, there will be work on Insight and maybe the logviewer too, will note this anyway.
I will get this fixed up. What happened is that this field was added later, but the export to CSV code didn't get updated. I'll take care of it in no time...
Thanks!
I've now fixed this issue. I am releasing a beta now, and we have had a minor update planned already. So, after some testing, it will go final.
